Engine is slooowly coming together, Here's the shortblock |
Qarl |
Jun 13 2003, 03:31 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Finally remembered to bring the camera to take a picture of the shortblock. or the mid-block. It's not quite a long block yet.
Cylinder heads are getting new studs, valves, and valve springs. Cams are on order. Nice and shiny 98mm J&E Pistons and cylinders. Regards, Attached image(s) |
Qarl |
Jul 25 2003, 06:45 AM
The mechanical tensioners are just as reliable as the pressure-fed ones. They just need to be adjusted at around the same intervals as the valves. They tend to be a bit noisier at startup but then tighten up after the engine warms up and expands.
Ask any racer about mechanical vs. hydraulic and you will get your answer. The majority of the mechanical failures is because of the old Ronco train of thought... "set it and forget it". |
Lo-Fi Version | Time is now: 5th June 2024 - 10:40 AM |
