| MoveQik |
Jul 26 2005, 05:18 PM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
When looking at the back of my car, the exhaust really looks like crap. I would love if a quick coat of that high-temp stuff would clean it up a bit. Any experience as to how well it would hold up on the exhaust?
| Garland |
Jul 26 2005, 07:59 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Try VHT Hi-temp Engine Enamel 550 f degree paint I have used it on many parts. The trick is to let it dry, then run the exhaust till warm. Let it cool and so on. The curing of the paint at a slow rate of incresed heating works. I like the semi-Black that is a GM satin black color # SP-139. For a flat black Wurth makes Hi-heat exhaust paint # 0892 9186 they say "won't burn off" 400 degree minimum to cure. You can get Wurth at Pelican, Ramchargers and your top end flaps have VHT.
MW 914 High-temp paint Jul 26 2005, 05:18 PM
! It looks gud for awhile then ya gotta hit it again... Jul 26 2005, 05:30 PM
carr914 I've had a high temp paint on the muffler on m... Jul 26 2005, 05:40 PM
914GT I had my headers coated by Doc's Engine here i... Jul 26 2005, 05:56 PM
MW 914 Thanks for the advice. Since this exhaust is some... Jul 26 2005, 06:05 PM
Howard I've had good luck with Rustoleum BBQ paint. ... Jul 26 2005, 09:59 PM
mrobin i use the stuff from Eastwood... they have a high ... Jul 27 2005, 04:22 AM
bd1308 i tried some good enamel paint and it turned diffe... Jul 27 2005, 06:23 AM
JmuRiz I'd try the rustoleum BBQ paint, I redid my bi... Jul 27 2005, 10:50 AM
jdogg I used the POR15 high temp exhaust paint. It seems... Jul 27 2005, 12:19 PM
Travis Neff I did the high temp silver, 1500 degrees or someth... Jul 27 2005, 12:31 PM
ejm ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:52 AM |
