Need your help, Oil temp sender |
qa1142 |
Jul 26 2005, 07:05 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Ok, so ~ 10 days ago I installed temp sender....
Taco plate leaked like crazy. So tonight I drained oil and pulled it back apart. choices: 1) re-install with new gasket and more sealer 2) put old cover back on and install the temp sender I got that replaces drain plug. Issue taco plate sender says 200 deg and drain plug says 150 deg. So what do I do? I could swap temp for oil presure too.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) What would you do? |
ematulac |
Jul 27 2005, 12:46 AM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
I just went through the same thing.
Did pretty much what you did, but I had a to make my own gasket to go between the plates. I used lots of sealant, and replaced the crush washers with larger fiber washers. I ran the car for a few minutes and it seemed to be leak free. The real test will be the drive to work tomorrow :crosses fingers smiley:. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:18 AM |
