> Extra! Extra! Wavy washer commits terrorism, Suicicidal jump into bowels of engine
DNHunt
post Jul 31 2005, 04:01 PM
914 Wizard? No way. I got too much to learn.
In an apparent act of suicide an 8mm wavy washer jumped to its death in an attempt to derail a Type IV engine build. Late last night when it believed security would be lax due to fatigue the accused dove from a rocker arm stud directly down a pushrod tube. The washer's fall was arrested by the lifter in the lifter bore where it rested for approximately 5 minutes. When it was discovered in hiding several attempts were made to recover it. The recovery team, in great distress, attempted to coax the washer out of it's hideout without the use of violence. As the evening wore on it became apparent that the terrorist washer was intent on self distruction and at approximately 8:00 PM it made an attempt at escape, bolting through an oil return passage into the crankcase. The evening ended with the situation at a standoff and recovery efforts would begin again in the morning.
Recovery attempts began again at approximately 3:30AM in an attempt to surprise the terrorist washer and because the recovery team could not sleep. Under clear skies and a creasent moon the confrontation began anew. Early attempts to scout for the washer were unsuccessful and further negotiations proved fruitless. The decision was made to go in after the culprit so at approximately 4:00 AM preparations were made to split the case and recover the washer.
The twenty case and through bolts were removed and the engine case was opened without difficulty. Little resistance was offered. Curses were heard from the recovery party as they probed futher into the terrorist washer's lair. Attempts to spot the perpetrator were fruitless until it was found hiding up against the rubber gasket holding in the windage tray. When confronted the forsaken washer gave up without a fight and it was removed to await it final judgement.
Clean up efforts continued for several hours and at last check the area is peaceful and life is returning to normal.
Security efforts are being redoubled and random searches will be enforced.
The accused is in custody and is awaiting trial on numerous charges including attempted murder of an engine. There is some doubt whether an impartial jury can be found and the trial may need to be moved. The washer is claiming he is innocent and that he tripped due to disregard for his personal saftey by the engine builder one DN Hunt. An attorney for the washer is threatening a suit in civil court. Rumor on the street is that the washer will not survive long in custody. (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
Here is the washer during his last moment of freedom.
Dave
ClayPerrine
post Jul 31 2005, 04:12 PM
Put him to the cutting torch!!!!
Burn the Witch.. ..errr .... Washer!!! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
DNHunt   Extra! Extra! Wavy washer commits terrorism   Jul 31 2005, 04:01 PM
goose2   http://www.914world.com/bbs2/htm...   Jul 31 2005, 04:08 PM
SpecialK   http://www.914world.com/bb...   Jul 31 2005, 04:08 PM
Brando   http://www.914world.com/bb...   Jul 31 2005, 04:09 PM
McMark   Ouch. Let him burn. Bad washer, very bad washer...   Jul 31 2005, 04:11 PM
ClayPerrine   Put him to the cutting torch!!!! ...   Jul 31 2005, 04:12 PM
redshift   http://www.914world.com/bbs2/htm...   Jul 31 2005, 05:31 PM
Lawrence   Damn... I agree with Miles twice in one year?   Jul 31 2005, 05:35 PM
rhodyguy   a diving save, good one dave. couldn't you hav...   Jul 31 2005, 06:21 PM
Cap'n Krusty   I hope it wasn't really an 8mm washer, because...   Jul 31 2005, 07:01 PM
morphenspectra   after standing most the day in a 99 degree shop sh...   Jul 31 2005, 07:39 PM
MattR   Well done! Good thing you got that thing out ...   Jul 31 2005, 10:21 PM
BarberDave   http://www.914world.com/bbs2/...   Aug 1 2005, 05:49 AM
tdgray   Sir... as Mr. Washer's attorney I must insist ...   Aug 1 2005, 06:11 AM
Korijo   hilarious and sad http://...   Aug 1 2005, 11:42 AM
redshift   I don't know if it would have damaged the case...   Aug 1 2005, 12:00 PM
Cap'n Krusty   <...   Aug 1 2005, 12:02 PM
Dave_Darling   Kap'n, it's just Miles.... <...   Aug 2 2005, 12:01 AM
DNHunt   Cap'n It actually is 8mm as the studs were re...   Aug 2 2005, 07:28 AM
redshift     Aug 2 2005, 07:44 AM
bondo   Haha, I use WD-40 on paint, on purpose, to remove ...   Aug 2 2005, 09:22 AM
Jake Raby   Yep, we ALWAYS upgrade the studs to 8mm- The 7s en...   Aug 2 2005, 10:46 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 05:36 AM
