> Fuel Injector connectors on EFI Harness, Does it matter which goes where?
D1A3
post Jul 31 2005, 09:01 PM
Gruppe Neun Vierzehn Südosten
Hi everyone,
I got my 2.0 engine back from a rebuild and have been workign this weekend to get it up and running.
The question I have is regardign the EFI harness. It's obvious which 4 connectors go to the injectors, but what is less obvious is if it matters which harness connector goes on which injector on each side of the engine. I found that it also does not matter which way you plug the harness into the injectors either. I'm hoping for some clarification before I connect my gas lines back up and try to start the car (and create any poblems!). Also, on the drivers side of the engine, one of the connectors has a white rubber covering, wheras the others all have black. I put the white one on #1, assuming it was correct.
Any guidance is MUCH appreciated.
--Jason
LongARM
post Aug 1 2005, 10:04 AM
it's better to burn-out , then it is to rust
i've seen that avator before.....hmmmmmmmmm (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif)
- Lo-Fi Version Time is now: 15th July 2025 - 03:25 AM
