| dflesburg |
Aug 4 2005, 06:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
does the stock speedo work after switching to the 915 gearbox?
| ClayPerrine |
Aug 4 2005, 07:40 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
If you get the later 915 tranny, the electronic speedo is easy. When you flip the ring and pinion, install new bearings. On the side of the differental opposite the ring gear there is a disk with some magnets in it. It has to be moved over to the back side of the ring gear. But be careful. You have to make sure that the disk and shim thickness doesn't change on each side's bearing. Otherwise the ring gear will not correctly mesh with the pinion, and your tranny will howl like a bunch of weiner dogs!
Then you have to run a pair of shielded wires from the tranny to the back of the speedo. You then add a power wire to run the speedo, and you are done. Easy, No? |
dflesburg 915 tranny guys Aug 4 2005, 06:54 AM
RON S. In a word,NO.
I don't know what type of 915... Aug 4 2005, 07:17 AM
michel richard What's involved in converting to an electric s... Aug 4 2005, 07:21 AM
flesburg Why do you need a speedometer?
You never look at ... Aug 4 2005, 11:54 AM
flesburg see Aug 4 2005, 12:05 PM
GeorgeRud I just did the conversion with the Vellios kit. T... Aug 4 2005, 01:13 PM
ArtechnikA <... Aug 4 2005, 01:14 PM
SteveSr ![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 12:23 AM |
