Need some new meats or fender work, Tires Rub in the back |
Jaiden |
Aug 4 2005, 08:15 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So last night after some spirited driving I got really annoyed that when pushing the car the rear tires rub alot more than I thought that they would.
Out of nowhere there was a little Lift in the road and when I went over a nice load screech from the rubber hitting the fender. The driver side has the lip rolled under (although the job isn't great it dented the fender slightly) but the passenger side is untouched. I'm currently running a 195 60 R15 on what I believe to be on a 15 X 7 rim. I'm not sure of the offset. I was looking for some new tires but the sizing is tough to find since I want a good tire but don't want to go that much smaller. What tire size would be 1 inch narrower that the current set up? How hard is it to roll the lip or pull the fender without damaging the fender? What's the process? Can I do it myself or will it crack my paint or damage the fender? I've heard of the "bat" trick but it sounds alittle risky I eventually might go with mini flairs but I have to drive the car and don't want a blow out that might take out the fender. What to do? |
Mueller |
Aug 4 2005, 09:47 AM
you could add these to your budget : 911 vented rotor hubs for 4 lug cars..not cheap, but you only have to buy 'em once (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 03:01 AM |
