Electrical help |
Electrical help |
EJP914 |
Aug 7 2005, 07:58 AM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Have 73 1.7. Car will not start. Everything electrical works, lights are bright, radio, fan motors all work. I turn the key, the FI system makes its usual buzz sound, the red alternator light is on in the gauge cluster, and then nothing. Not a sound! I don't hear the typical click, click sound from a dead battery. It seems I have no power back to the starter. Starter doe not even try to turn. I charged the battery last nite thinking that might be the problem, but this morning...zippo! All fuses and relays are OK. Is it possible the battery doe not have enough juice to turn the car over? Battery is about 5-6 yrs old and car is not driven much, but it has always turned over. Car stared yesterday morning, went for a drive, but last evening is when all of this BS started. Any suggestions??? I appreciate all help and responses. Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
rhodyguy |
Aug 7 2005, 10:18 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the car started fine yest when it was cold, correct? then you came home after a drive and it failed to start when hot? when the starter finally gives it up for good, it doesn't matter whether it's hot OR cold. even the old smacking on the starter with a hammer fails to help. have you ever replaced the starter? have you cleaned the bat terminals and posts?
k |
Lo-Fi Version | Time is now: 8th June 2024 - 06:16 AM |
