96MM Cylinder and Piston Install, Running real bad after install |
DanPMan |
Aug 7 2005, 06:40 PM
Newbie Group: Members Posts: 7 Joined: 3-June 05 From: Las Vegas, NV Member No.: 4,192 |
Just installed a 96MM piston and cylinder set into our 75 914-2.0. Fuel injection has been removed and replaced with a 32/26 DFV. Upon restart, there's a lot of backfiring both through the intake and exhaust. Runs like #$$#@%!!! with no power whatsoever. So far we've reset the carb per Weber initial set-up procedures and performed some initial timing. It idles, but hydrocarbons read at well over 8000 and the CO% was at 5 to 7%. So we're probably real rich. Probably should be rejetted...
Question.... when we installed the piston and cylinder sets, we also performed a valve seat rework (with a Neway by hand). All valves were verified to seat. Do you think the backfiring and no power condition is due to any other cause besides the carb and timing set-up????? |
redshift |
Aug 7 2005, 10:00 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
popping.. i&o... and..
Yeah, valves.. may even take a sweet spot adjustment, with a lil carb, and big... knockers? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Lo-Fi Version | Time is now: 1st June 2024 - 05:26 AM |
