GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
My Harbor Freight flyer came in the mail yesterday (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
I seen this welder and it has me thinking (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) I have NEVER welded anything before. I have had a few times in the past few years that I could have really used one or someone that had one. I don't have any real welding that needs to be done on the teener other than replacing the bottom section of the passenger side jack post plate. But I want one so here's the specs: Chicago Eletric Welding System 87 AMP, 115 VOLT FLUX AND MIG WELDER For mild steel, stainless steel, and aluminum. Weld with gas or perform flux cored gasless operations. Welding current range: 25 to 87 amps Input: single phase 115 volts, 60 Hz Open voltage: 19 to 30 Duty cycle: 20% @ 75 amps, 45% @ 50 amps Draws 21 amps @ 120 volts Weldable wires: 0.023'' to 0.035'' steel and stainless steel, 0.030'' to 0.035'' aluminum, 0.030'' flux-cored Includes: 2 lb. spool of flux cored wire, handheld face shield, brush hammer, fuse power line; Weight: 55.8 lbs. Attached image(s) ![]() |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
It's a decent one IMHO. The infinite control is a plus compared to others with just low, med, and high.. I use mine on the highest setting most of the time as it is kinda weak as welders go. I've had mine for four years with no problems. welded so many things, so many ways. It definately is a light duty machine.... The inert gas option is a plus. I tested the 20% duty cycle of mine and it was absolutely true. After the thing heats up, for every one minute of welding, it needed 4 minutes of cooling. A 10 minute rest usually resets the built in thermo protection. I've done BBQ's to 3/16" steel. I did however get the largest wire tip it suggested. For sheet metal they're great. I do weld like the guys at the O.C.C. and tack, tack, tack. =-) My second welder is a 220V AC/DC reverse polarity stick welder for the thick knarly work. I wish that one was more portable..... (heavy beatch) Got that one used on Craigslist. Half price and used NEVER. I had parts start to come apart with the 110V welder. It became a pain in the @ss trying to find parts to repair it. I don't know if i'd buy another 110V wire feed used just because I might inherit some little nagging problems. (Hey , reminds of a 914.....) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 5th July 2025 - 06:50 AM |
