> Would this be a good lite duty welder, Chicago Electric
GaroldShaffer
post Aug 9 2005, 12:13 PM
You bought another 914?
My Harbor Freight flyer came in the mail yesterday (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
I seen this welder and it has me thinking (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) I have NEVER welded anything before. I have had a few times in the past few years that I could have really used one or someone that had one. I don't have any real welding that needs to be done on the teener other than replacing the bottom section of the passenger side jack post plate. But I want one so here's the specs:
Chicago Eletric Welding System
87 AMP, 115 VOLT FLUX AND MIG WELDER
For mild steel, stainless steel, and aluminum. Weld with gas or perform flux cored gasless operations.
Welding current range: 25 to 87 amps
Input: single phase 115 volts, 60 Hz
Open voltage: 19 to 30
Duty cycle: 20% @ 75 amps, 45% @ 50 amps
Draws 21 amps @ 120 volts
Weldable wires: 0.023'' to 0.035'' steel and stainless steel, 0.030'' to 0.035'' aluminum, 0.030'' flux-cored
Includes: 2 lb. spool of flux cored wire, handheld face shield, brush hammer, fuse power line; Weight: 55.8 lbs.
tdgray
post Aug 9 2005, 01:37 PM
I would go with a Lincoln 110 if your thinking of small but mighty.
I have one and have been very pleased. I have mine outfitted with the mig kit also. Lays out a nice bead... well as nice as my crappy welding skills allow. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 5th July 2025 - 06:30 AM
