| tdgray |
Aug 10 2005, 09:51 AM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
So I figure I better start contributing with some real content rather than stupid jokes and snide remarks. So here goes.
I purchased my 1973 1.7L for $300.00. Damn good thing to because there was about 8 thousand times the rust that I could see (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (duh!) Before I tore the car apart I got the engine running. PO said fuel pump was bad. Turned out the relay was bad and in his attempts to fix the problem he reversed the fuel lines. Put a new relay fired right up...ran like crap but still it ran. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) After stripping all interior, electrical and accesories from the car the real work started. Nothing more than expected just a long list. Some of the problem area identified. 1) Rust in longs 2) Rear trunk and valance panel totally rusted out 3) Floorboards very rusted out - quite a few holes 4) Sill plates and door jams very questionable 5) Typical battery tray and engine shelf damage 6) Front trunk rusted around AC unit 7) Sail panels - bad PO repair with Bondo Just one note for the rest of this, I am not CptTripps... these pic's are over a years time span. The reason I am finally posting all this is to motivate me to get 'er done. It may not be realistic but I am still shooting for the FFC this year. I really have to get moving NOW! |
| CptTripps |
Aug 10 2005, 09:53 AM
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
Man...you really have your work cut out for you...(No pun intended)
We'll motivate you...just you wait. |
tdgray Yet another progress thread from TG Aug 10 2005, 09:51 AM
tdgray First task at hand was to cut the trunk and valanc... Aug 10 2005, 09:52 AM
tdgray All buttoned up... still needs finishing and rear ... Aug 10 2005, 09:53 AM
tdgray Next Task...
Drop the engine. Easy job took my br... Aug 10 2005, 09:54 AM
tdgray Damn that engine looks big when it is not in the c... Aug 10 2005, 09:55 AM
tdgray Hell Hole after engine removal htt... Aug 10 2005, 09:55 AM
tdgray Big Problem when removing the engine... had to cut... Aug 10 2005, 09:56 AM
tdgray Next Task.
Longs are solid but have some major pa... Aug 10 2005, 09:57 AM
tdgray Thanks to Dr. Evil for the clam shells... Just wha... Aug 10 2005, 09:59 AM
tdgray My buddy Dave (acting like a dork). Leveling the c... Aug 10 2005, 10:00 AM
tdgray Finished Welding... still a little clean up to do ... Aug 10 2005, 10:01 AM
tdgray Other side... rust was not as bad. Less patching t... Aug 10 2005, 10:02 AM
tdgray Stripped Down. Doors and targa off now that I trus... Aug 10 2005, 10:04 AM
tdgray Door jamb carnage. Also firewall damage along with... Aug 10 2005, 10:05 AM
tdgray Cut the door jamb out. Normally you would pull the... Aug 10 2005, 10:07 AM
tdgray Firewall and inner fender repairs... no making fun... Aug 10 2005, 10:08 AM
tdgray New door jambs. I test fit these suckers about a m... Aug 10 2005, 10:10 AM
tdgray Next new door sills. Pretty easy installation. Aug 10 2005, 10:12 AM
tdgray Test fitting donor lower fender. Original was abso... Aug 10 2005, 10:13 AM
tdgray New fender welded in... major finishing to do. Aug 10 2005, 10:15 AM
tdgray My car needs a special ed class... it stutters PPP... Aug 10 2005, 10:16 AM
tdgray Oh BTW....
Doug when I was putting these pic tog... Aug 10 2005, 10:18 AM
tdgray Just some rattle can primer to protect the bare sp... Aug 10 2005, 10:19 AM
tdgray For those of you that do not know what All Metal i... Aug 10 2005, 10:22 AM
tdgray That's it for now. More pics at home on the Ca... Aug 10 2005, 10:23 AM
Headrage Great pics.
I've used the All Metal stuff o... Aug 10 2005, 10:59 AM
Travis Neff Great job!! Aug 10 2005, 11:08 AM
CptTripps Aug 10 2005, 11:10 AM
tdgray Aug 10 2005, 02:46 PM
tdgray http://w... Aug 11 2005, 09:02 AM
tdgray Jerry,
These are designed to fit over top of the ... Aug 11 2005, 09:55 AM
JerryP Thanks for posting the pictures Todd. I have most ... Aug 11 2005, 10:13 AM
Lou W Great progress, keep the pictures coming. Aug 11 2005, 12:20 PM
tdgray One small victory this week. ... Aug 12 2005, 05:08 PM
CptTripps My simple fix for this was that I have a digital c... Aug 12 2005, 08:40 PM
brp914 I'm jealous. You guys get all the rust! Aug 12 2005, 09:00 PM
Engman Nice job!
To all those in the far off land o... Aug 12 2005, 09:11 PM
tdgray Well... my two days off came and went.
I spent ha... Aug 17 2005, 06:28 PM
tdgray Typical battery tray rust.
I had already cut ( in... Aug 17 2005, 06:33 PM
tdgray Other nastyness from this side.
Amazingly the oth... Aug 17 2005, 06:35 PM
tdgray Fabricated and started welding in patch... and no ... Aug 17 2005, 06:41 PM
tdgray Sorry for the somewhat " Andy" quality pics.
My a... Aug 17 2005, 06:44 PM
tdgray Here is a fitting of the new engine shelf piece.
... Aug 17 2005, 06:49 PM
tdgray Tacking the rest in.
I am such a freaking baby wh... Aug 17 2005, 06:52 PM
tdgray On to the battery damage.
Most of which was cause... Aug 17 2005, 07:03 PM
tdgray And in my usual style (read: yes I went like hell ... Aug 17 2005, 07:06 PM
tdgray Don't worry... this is only "Rock Guard"
It i... Aug 17 2005, 07:12 PM
tdgray Oh forgot to add one more thing.
Before everybody... Aug 17 2005, 07:16 PM
siverson Man, looks like good work, but I can't believe... Aug 17 2005, 07:23 PM
tdgray ... Aug 17 2005, 08:18 PM
CptTripps ... Aug 17 2005, 08:46 PM
tdgray A bit of bad news to go along with all of this
I ... Aug 18 2005, 05:53 AM
CptTripps coughCARBScough Aug 18 2005, 06:08 AM
tdgray h... Sep 6 2005, 07:08 PM
tdgray Here is final fitting before finish welding. Fende... Sep 6 2005, 07:12 PM
tdgray All welded up (hah.. I forgot to take pics so you ... Sep 6 2005, 07:14 PM
tdgray Here is the really UGLY http:/... Sep 6 2005, 07:19 PM
tdgray Took a little break from body work to work on the ... Sep 6 2005, 07:21 PM
tdgray Oops forgot the pic. That's enough ... Sep 6 2005, 07:31 PM
tdgray Let the tear down begin Sep 6 2005, 07:32 PM
tdgray Oh BTW... the tool box in the prevoius pic belongs... Sep 6 2005, 07:35 PM
tdgray The parts boxes grow http://www.91... Sep 6 2005, 07:37 PM
tdgray Stripped down naked... or almost. This is as far a... Sep 6 2005, 07:38 PM
tdgray You would think with a valve cover this bad... the... Sep 6 2005, 07:40 PM
tdgray Not too bad... in definite need of adjustment. but... Sep 6 2005, 07:41 PM
tdgray Here she is after a nice bath. Took me an hour to ... Sep 6 2005, 07:43 PM
tdgray Tonight's progress
They could be better but, ... Sep 6 2005, 07:46 PM
tdgray Enough for tonight... the wife is giving me the "a... Sep 6 2005, 07:48 PM
aircooledboy Todd, you are rockin' bud. ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:08 PM |
