Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Adjusted the cable once this month already. Now the clutch pedal is getting harder to push in. So, almost clutch season?
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
When I had an increasingly stiff pedal (only thing that gets increasingly stiff as I get older (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) ), I pulled the trans and found that clutch dust had dirtied up the little bit of grease on inside diameter of the throw out bearing to the point that there simply was no lubrication going on there anymore.
There is a small groove inside the throw out that is meant to be filled with a high temp bearing grease to help the bearing slide up and down the tube around the input shaft. I learned all this stuff from Brad Mayeur, BTW. Greased it as Brad suggested, and it has been smooth ever since, even with a stiff KEP pressure plate. |
Lo-Fi Version | Time is now: 1st August 2025 - 10:11 AM |
