Ball Joint, Replacement Questions |
johnmhudson111 |
Aug 15 2005, 01:52 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
So I am wacking away on the pickle fork seperating the 914 strut from the a arm and I notice I have effectivly destroyed the ball joints rubber cover and grease (I assume) is everywhere. I am thinking, this isn't good. No problem I got another set on the 911 a-arms, happy times again, but wait a second it turns out there is a special tool that you have to have to unscrew the nut on the bottom of the ball joint. Pelican has them for around $50. So that leads me to my two questions:
1. is there another way to remove the ball joint nut? if not is there a cheaper source? 2. is it unwise to use a used ball joint? Don't mind buying new but hey if you ain't got to.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
TravisNeff |
Aug 15 2005, 07:33 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I had a helluva time trying to get mine off, I tried the chisel technique but basically hosed up the nuts, did the home made pipe wrench with no luck. I took the the car to the local Pcar shop when I did an alingnment and gave them the parts and had them do it. Best $60 bucks I spent, they even had a bitch of a time getting them off.
Lo-Fi Version | Time is now: 1st June 2024 - 06:21 PM |
