> drain plug., anyone know what size allen it is?/
jleighton88
post Aug 16 2005, 10:44 PM
i was just curious if anyone knew what size allen the drain plug is. i was gunna change my trans. oil to synthetic. but i need a huge allen to take out the drain plug.
thanks
Jon
Jake Raby
post Aug 16 2005, 10:56 PM
Engine Surgeon
Lets veryify its the tranny drain plug first- some TIV engines had allen headed drain plugs... They are 6mm
If it is the tranny plug ALWAYS remove the plug on the side first before draining the oil.... This is because you may have a seized fill plug that will keep you from ever filling the tranny in the future. Removing the fill plug first ensures you won't be getting a nasty suprise later when its time to fill R' up..
You can sometimes clamp a 17mm headed bolt in a pair of vise grips to remove it if you don't want to buy the tool..... I welded a bolt into a socket years ago and made my own apex for the job and never did buy the tool!
jleighton88   drain plug.   Aug 16 2005, 10:44 PM
Ferg   17 mm   Aug 16 2005, 10:47 PM
Jake Raby   Lets veryify its the tranny drain plug first- some...   Aug 16 2005, 10:56 PM
bondo
- Lo-Fi Version Time is now: 1st July 2025 - 08:02 AM
