| ThinAir |
Aug 17 2005, 06:17 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,576 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
As I'm pulling out of a parking lot today, I hear a clunk from the rear end and the engine revs because there is no power going to the rear wheels. I've had a few issues with not getting it into first all the way so I figure it just popped out of gear, but no - it can't be that easy. So AAA brings me home and I check out the grub screws - nope, they are both in place too!
So that eliminates all the easy things and I think it points to something internal (and really bad/expensive) inside the transmission. It's a 73 with side-shifter tranny. Here's what I know - 1. It seems to shift fine into all gears. I've visually confirmed the movement of the shaft on the transmission. 2. With one rear wheel in the air and one on the ground, if I put it in gear and let out the clutch the wheel in the air turns in the expected direction. There are some clunking sounds to be heard that make me think something isn't right with the synchro mechanism. It sounds like they are coming from the other wheel "slipping" as it is supposed to do. 3. There is no apparent problem with the clutch operation. Before I pull the tranny, what am I looking for? If this set of symptoms sounds familiar, what do you think it is? Can I determine the cause by removing the side-shifter mechanism or do I need to take off the nose cone? Who in Arizona should I take it too? (I'm going to be in Phoenix this weekend.) Since putting it back on the road on June 11th, this car has been a dream to drive. Fortunately I've got another transmission so there will be no problem with making it to the Red Rock Classic in September, but I'm still bummed about it. |
| VegasRacer |
Aug 17 2005, 10:51 PM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 9,131 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
Good deal Ernie. If something is gonna break, at least it was well before the event and close to home. |
ThinAir914 Transmission Problem Aug 17 2005, 06:17 PM
bondo Your CV joint came loose. 4 screws and 2 pins and ... Aug 17 2005, 06:19 PM
bondo (could be a broken CV too)
You really need both ... Aug 17 2005, 06:21 PM
ThinAir914 Update -
Just like Royce said, something isn... Aug 17 2005, 06:50 PM
Andyrew clunk clunk clunk... Thats cv all right....
Chec... Aug 17 2005, 10:35 PM
VegasRacer ![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 03:12 AM |
