blabla914 |
I like primer ![]() ![]() Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None ![]() ![]() |
So I got my -16 braided line and the support coil for it. I'm still waiting for some fittings before I can get this done. In the mean time I'm playing around with the coil and the hose. I've looked through all my books, but I've got zip on using the support coil. Anybody have any proven techniques to get the coil into the hose?
You're basically trying to shove a slinky into a rubber hose that's got an ID the same size as the OD of the coil. Lots of lube seems to help, but I can see getting shredded by the exposed end of the hose. As always, any help much appreciated. Thanks, Kelly |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Use the coat hanger , bed the ends, so they lock together ,Then you can turn it , turning it reduces the the diatmeter and it it pull in , with couple of twist you will get it , then pull out the end , cut of the bent end , push it back in,
hope this helps |
Lo-Fi Version | Time is now: 16th June 2024 - 05:13 PM |
