Weltmeister sway bar = rattle trap, how to fix? |
cha914 |
Aug 21 2005, 02:01 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Ok, I have a 21mm welt sway bar up front that the PO had in the car. Before my last big trip ,MUSR 6, I upgraded the droplinks to the adj welt jobbies and I took the bar out and relubed the bushings and it quited down for quite a while.
However, after ~600+ miles of OK roads and more pounding here in Austin, it is making more noise than ever. In steady corners its quiet, sharp ones I hear a crack and then its good, and on bumpy roads it is horrible....crack, crack, pop, pop...etc When I took the bar out the last time I noticed that the thrugh body bushings allowed the bar to move side to side quite a bit (like 1inch plus) so I have some new bushings that are stepped and will hopefully hold the bar in the center: (IMG:http://www.pelicanparts.com/catalog/images/suspension/sway_bar_cup_bushing.JPG) Also, it seems like one of the heim joints on the droplinks has some play in it and has got to be making some noise, these things have maybe 2 - 3000miles on them, now I know they probably arn't the best, but this seems a little soon. What heimjoints do you guys like for replacements, where do you buy them from? or are heimjoints always goinig to be this loud? Finally, I just got a new valance and want to attach with Dzus fastiners, were is a good place to get enough to do 6 fastiners without going broke? And if you are still reading at this point...you rock (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Tony Attached thumbnail(s) |
SirAndy |
Aug 22 2005, 12:51 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if yours is a stock bar, it shouldn't. if someone else installed it later, they might have installed in just a bit off-center. the clearance between the bar and the tank is *tight* and the bar can flex a bit. in my case, the bar is a bigger OD than stock and when i removed the tank, i could see the marks where it was hitting ... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Andy |
Lo-Fi Version | Time is now: 11th June 2024 - 05:24 AM |
