Weltmeister sway bar = rattle trap, how to fix? |
cha914 |
Aug 21 2005, 02:01 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Ok, I have a 21mm welt sway bar up front that the PO had in the car. Before my last big trip ,MUSR 6, I upgraded the droplinks to the adj welt jobbies and I took the bar out and relubed the bushings and it quited down for quite a while.
However, after ~600+ miles of OK roads and more pounding here in Austin, it is making more noise than ever. In steady corners its quiet, sharp ones I hear a crack and then its good, and on bumpy roads it is horrible....crack, crack, pop, pop...etc When I took the bar out the last time I noticed that the thrugh body bushings allowed the bar to move side to side quite a bit (like 1inch plus) so I have some new bushings that are stepped and will hopefully hold the bar in the center: (IMG:http://www.pelicanparts.com/catalog/images/suspension/sway_bar_cup_bushing.JPG) Also, it seems like one of the heim joints on the droplinks has some play in it and has got to be making some noise, these things have maybe 2 - 3000miles on them, now I know they probably arn't the best, but this seems a little soon. What heimjoints do you guys like for replacements, where do you buy them from? or are heimjoints always goinig to be this loud? Finally, I just got a new valance and want to attach with Dzus fastiners, were is a good place to get enough to do 6 fastiners without going broke? And if you are still reading at this point...you rock (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Tony Attached thumbnail(s) |
MartyYeoman |
Aug 22 2005, 01:49 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
I had a lot of noise also.
I tracked it down to a loose fit-up between the rod end and arms. Filing new surfaces onto the arms quieted them right down. Adjustable drop links also help to remove binding. Get somone to sit in the driver's seat for you when you adjust them. I also replaced the gas tank felt pads with sorbothane (.125" thick) from McMaster-Carr. (8514K61) The stuff works great and is available in various thicknesses. Good for tank clearance adjustments. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:42 AM |
