Weltmeister sway bar = rattle trap, how to fix? |
cha914 |
Aug 21 2005, 02:01 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Ok, I have a 21mm welt sway bar up front that the PO had in the car. Before my last big trip ,MUSR 6, I upgraded the droplinks to the adj welt jobbies and I took the bar out and relubed the bushings and it quited down for quite a while.
However, after ~600+ miles of OK roads and more pounding here in Austin, it is making more noise than ever. In steady corners its quiet, sharp ones I hear a crack and then its good, and on bumpy roads it is horrible....crack, crack, pop, pop...etc When I took the bar out the last time I noticed that the thrugh body bushings allowed the bar to move side to side quite a bit (like 1inch plus) so I have some new bushings that are stepped and will hopefully hold the bar in the center: (IMG:http://www.pelicanparts.com/catalog/images/suspension/sway_bar_cup_bushing.JPG) Also, it seems like one of the heim joints on the droplinks has some play in it and has got to be making some noise, these things have maybe 2 - 3000miles on them, now I know they probably arn't the best, but this seems a little soon. What heimjoints do you guys like for replacements, where do you buy them from? or are heimjoints always goinig to be this loud? Finally, I just got a new valance and want to attach with Dzus fastiners, were is a good place to get enough to do 6 fastiners without going broke? And if you are still reading at this point...you rock (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Tony Attached thumbnail(s) |
Brando |
Aug 22 2005, 07:50 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I've got an adjustable 21mm welt up front... No creaks bumps or bangs. The heims and everything are good. What kind of lubrication did you use? Silicone or graphite based? I've found better creak and bind-reducing results with graphite-moly mixes. If the bar was installed right you shouldn't have clearance issues with the gas tank. To raise the tank up a bit, you can move those big rubber spacers on the sides of the tank around. Set them down further and the gas tank will sit up higher, then strap it down.
Lo-Fi Version | Time is now: 2nd June 2024 - 11:02 AM |
