Starter won't turn after clutch rebuild, is it a coincidence? |
914zim |
Aug 23 2005, 07:50 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Dudes:
I finally finished replacing the clutch (took waaay longer than it should've) tonight and tried to fire it up after months of down-time... turn key, hear fuel pump run, see red lights on dash come on, but the starter doesn't turn or make any noise at all. Did I forget something on reassembly or is this purely a coincidence? I did check the ground strap from the tranny and the battery is fully charged (all night with trickle charger). All lights work as well. Speaking of the starter (I know I asked this before), do both heavy wires go to the post on the starter and does the slide on connector go to either spade? (there are 2). Is it possible to connect the starter incorrectly? Also, I have a remote starter switch. Does it matter which connections you connect to on the starter? One on the post and the other on the flat spade? I connected the remote switch and tried it, but still nothing from the starter. What gives? Any ideas? Man, I was sooooo excited to get home today for some "quality 914 time", since I thought I'd be able to see if my clutch replacement was successful and I can't even get the damn thing started!! Any help (or encouragement) is greatly appreciated. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks! Andy... |
SLITS |
Aug 23 2005, 09:08 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
On the remote starter, you must connect to the large terminal that the + battery cable runs to and the spade terminal.
Electrons do not flow to the starter motor until the solenoid is engaged. You can test the starter motor by crossing the two big terminals with a screwdriver.....the motor should spin but will not engage the bendix drive. Running from the + cable to the spade terminal should engage the solenoid which will engage the Bendix and spin the motor. If nuthin happens, the solenoid / starter has taken a crap or you don't have power from the battery or a good ground on the starter. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:01 AM |
