what in the world is my rattle |
bd1308 |
Aug 24 2005, 12:29 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
not dizzy, not pre-ignition....(present in all extremes of timing)
what in the world could this be? did i snap a piston ring or something, is it piston slap, engine ticking until it goes KABLOOM or what? sounds like someone put a nut in the fan and its goign clak clak somewhere...under moderate acceleration.. seems vibration related really, as when i first let out on the clutch i hear it for a second. |
tat2dphreak |
Aug 24 2005, 12:41 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
maybe you are running too lean from feeding your engine through a fucking straw... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
is there a "pinging" sound? loose valves? when was your last valve adjust? did your VW mecahinc friend do it? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) i HIGHLY DOUBT you sontaneously dropped a piston ring or a wrist pin... but with you, who knows? did you do a compression check? do you know HOW to do a compression check? help us out here... we can't heard it over the net through your post... or take it to a real mechanic that KNOWS type 4s... not just type 1s |
Lo-Fi Version | Time is now: 17th June 2024 - 10:40 AM |
