Starter won't turn after clutch rebuild, is it a coincidence? |
914zim |
Aug 23 2005, 07:50 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Dudes:
I finally finished replacing the clutch (took waaay longer than it should've) tonight and tried to fire it up after months of down-time... turn key, hear fuel pump run, see red lights on dash come on, but the starter doesn't turn or make any noise at all. Did I forget something on reassembly or is this purely a coincidence? I did check the ground strap from the tranny and the battery is fully charged (all night with trickle charger). All lights work as well. Speaking of the starter (I know I asked this before), do both heavy wires go to the post on the starter and does the slide on connector go to either spade? (there are 2). Is it possible to connect the starter incorrectly? Also, I have a remote starter switch. Does it matter which connections you connect to on the starter? One on the post and the other on the flat spade? I connected the remote switch and tried it, but still nothing from the starter. What gives? Any ideas? Man, I was sooooo excited to get home today for some "quality 914 time", since I thought I'd be able to see if my clutch replacement was successful and I can't even get the damn thing started!! Any help (or encouragement) is greatly appreciated. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks! Andy... |
914zim |
Aug 24 2005, 06:44 PM
Guys:
I hope you're all still willing to help me figure this out. I only have a month or two of driving left here in WI and I'd sure like to get some driving in before the snow flies! I got some 914 time tonight, so I have an update: 1. Battery: took it out of the car and cleaned the terminals up. Also emery'ed the cable ends and cleaned up the chassis connection at the battery. The tranny ground strap was cleaned in WD-40 and secureley fastened during the clutch reassembly. After being charged on the trickle charger, it reads 12.5 volts exactly (while out of the car). It is a cheap-o Wal-mart battery, but it is only 2 years old. 2. Starter: have power at the yellow wire when ignition switch is on and at the post of the starter. I also shorted a screwdriver across the terminals and did hear the solenoid spin. I also banged on the starter case with a hammer. I now have the starter out of the car and connected the battery to it and got the drive gear to pop out, but it did not spin. Is it supposed spin? Is the starter grounded when it's bolter to the car? 3. Ignition switch: Since I get power at the starter (yellow wire) when I turn on the key, does that mean the switch is OK? I also get all idiot lights to come on and I hear the fuel pump running. I also connected a remote switch and it still does not start. I'm thinking it must be the starter, but I need a few more details on how to test it properly. If I need a new starter, I'm willing to drop the cash, but I would like to make sure that will fix the problem. Or is it the battery? Anyone got any other ideas on what to try? Thanks for any help, Andy... |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:02 AM |
