| GaroldShaffer |
Aug 24 2005, 02:45 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,640 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
Went to Tire Rack today and got the Kumho V710's mounted on my new (too me) Keizer rims. Went the with the 205 50 15 non heat cycled. Of course when I got home I had to put them on the car. I using 1/8" spacer on the rears and 1/4"on the front looks like I need to adjust my ride height a little. Front is setting 24 inches from floor to top of wheel arch, rears are at 22.
| Joseph Mills |
Aug 24 2005, 09:21 PM
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Garold, I'm assuming you are referring to your front end suspension, which is totally adjustable for ride height. You need to re-index your torsion bars. I quote Skline: Remove the end cap on the torsion bar on the inside by removing the adjustment bolt and pull the end cap off and change it to give you more adjustment. In other words, if it is at the top when you remove it, put it back in more towards the bottom and then put the adjustment bolt back in. Then you will have more adjustment. You will need a jack underneath the control arm to get it out and then to put it back in. If you're referring to the rear suspension, you need to give us more info. Nice wheels. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) .. |
itsa914 New Keiser rims w kumho tires mounted Aug 24 2005, 02:45 PM
itsa914 Tight fit in the rear, glad a PO somewhere along t... Aug 24 2005, 02:46 PM
tat2dphreak those are SLICK man!!! down right fuck... Aug 24 2005, 02:50 PM
itsa914 When I get the car painted ina year or two I will ... Aug 24 2005, 02:50 PM
Joe Ricard Damn you can go 4 wheelin wit dat car.
Don't w... Aug 24 2005, 02:51 PM
itsa914 <... Aug 24 2005, 03:24 PM
flesburg How much clearance do you have on the inside at th... Aug 24 2005, 03:32 PM
Aaron Cox ... Aug 24 2005, 03:38 PM
trekkor You can fit the 205/50/15 right in there.
I'v... Aug 24 2005, 03:50 PM
itsa914 ... Aug 24 2005, 07:55 PM
itsa914 <... Aug 24 2005, 07:59 PM
grantsfo <... Aug 24 2005, 08:01 PM
itsa914 Well I went out and tried to adjust the ride heigh... Aug 24 2005, 08:46 PM
itsa914 ... Aug 24 2005, 08:48 PM
Joe Ricard Not to be a pain the ass Grant but what is your ri... Aug 24 2005, 09:01 PM
grantsfo <... Aug 24 2005, 09:33 PM
Joe Ricard Did we mention this was going to be fun? So what ... Aug 25 2005, 05:42 AM
itsa914 ht... Aug 25 2005, 01:14 PM
Joe Ricard Well not my professional opinion but a wise old ma... Aug 25 2005, 01:26 PM
grantsfo Hoosier reccomends -3 degrees. I have a little ov... Aug 25 2005, 06:55 PM
Aaron Cox ... Aug 25 2005, 07:01 PM
J P Stein Joe:
Your temps in the rear are just right....or a... Aug 25 2005, 09:51 PM
Joe Ricard ![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 01:06 AM |
