rough running, Car hesitates at 2500-3000 rpm |
pfierb |
Aug 25 2005, 05:14 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Having a hesitation problem with my 73 2.0 ....at a steady 2500-3000 rpm car skips and misses....cleaned and adjusted the throttle switch no help....before I cleaned the switch hesitation started at a steady 2000 rpm...car seems to run worse after cleaning switch....runs great at higher speeds, idles smooth,starts right up.
Any ideas? Paul F. |
redshift |
Aug 25 2005, 07:38 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
TPS 99%.
M I have recently found that relays can fail in micro-second bursts, on-off-on-off-on-off. It will make any throttle position other than idle lean, and kill your motor. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:40 AM |
