| SM2270 |
Aug 24 2005, 08:17 PM
Newbie ![]() Group: Members Posts: 10 Joined: 15-August 05 From: SE, NH Member No.: 4,595 |
Is there a durable, high temp paint for the stock valve covers? Regular engine paint scratches off the first time you pop in the bail wire. I have an "industrial" rustoleum paint that may work. But it says not for over 200F.
Thanks. Scott. |
| Tobra |
Aug 26 2005, 07:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
For small parts like that, you could do it your self. There are all sorts of things you can use it on. It would not be cost effective if the valve covers are the only thing you were going to do, but it would be good for heater boxes, exhaust, wheels. Most anything you could paint you can powder coat. Check out
Eastwood They have more cool stuff than you can shake a stick at |
SM2270 Which paint for valve covers? Aug 24 2005, 08:17 PM
Kostamojen I used a High-temp (1200 degree) Cermaic spray pai... Aug 24 2005, 08:22 PM
SM2270 Does it last because it is ceramic? Or because th... Aug 24 2005, 08:39 PM
3liter914-6 Aug 25 2005, 12:00 PM
URY914 I use a nice cheap spray paint on mine. I spray th... Aug 25 2005, 12:42 PM
Tobra powdercoat is the way to go Aug 25 2005, 01:51 PM
SM2270 Thanks for the input. I was hoping for an over th... Aug 25 2005, 09:03 PM
Lawrence If you're gonna buy a powdercoating rig... che... Aug 26 2005, 08:39 AM
SM2270 Wow. Those prices for your own powdercoating equi... Aug 26 2005, 10:15 PM
dmenche914 Do not use powder coat, it is a good heat insulato... Aug 26 2005, 10:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:26 PM |
