| d914 |
Aug 27 2005, 02:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
just got a 911sc front end with a underbody sway, about 19mm, didnt check yet.
I have a 19mm thru body on the car. Options: - use the underbody as is - put new u-tabs on the 911 control arms and use thru body. - mix match 914/control arms with the 911 front???? Can I keep the 19mm torsions that way?? I gotta feeling the answer is cut and weld but thought I'd ask... |
| Britain Smith |
Aug 27 2005, 11:51 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I would recommend a thru-body bar in the front. I have a 160lb rear springs, 21mm Welt front bar, and stock rear bar. The set-up that Trekkor has and that I have (too a point) is a different way of thinking than some serious long-time racers out there (that is why some dissagree).
The idea is to run an oversize front sway bar (31mm) and stock torsion bars to keep the streetability and to allow for a huge range of adjustments. With large torsion bars, you can't make adjustments very quickly. -Britain |
d914 sway bar Aug 27 2005, 02:50 PM
Travis Neff I believe that the SC bar is 22MM and non-adjustab... Aug 27 2005, 02:57 PM
Travis Neff The other thought is to just put it in as is and s... Aug 27 2005, 02:59 PM
flesburg http://www.914world.com/bbs2/h... Aug 27 2005, 03:09 PM
d914 I measured the "new sway" it looks to be about a 1... Aug 27 2005, 03:21 PM
trekkor I have found my 31mm front bar with 200# rear spri... Aug 27 2005, 06:24 PM
Eric_Shea Early 911 underbody bar was 18mm (74-77). 20mm is... Aug 27 2005, 08:09 PM
bd1308 trekkor, link? Aug 27 2005, 09:42 PM
trekkor Marina a/x vid
click it! http:... Aug 27 2005, 10:21 PM
maf914 What size front torsion bars do 911SC's use? ... Aug 28 2005, 08:13 AM
johnmhudson111 <... Aug 28 2005, 06:00 PM
johnmhudson111 ![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 12:42 AM |
