Plug wire seals at engine tin, Is there a better way? |
URY914 |
Aug 30 2005, 07:21 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The plug wires I use are Accel 7mm (I think) and they are a universal application so they didn't come with those nice grommets to seal the holes in the engine tin.
Those holes should be sealed as best as possible to maintain the cooling air pressure on the heads. Any air that leaks out is not being used to cool the engine. I'm thinking of some type of small aluminum cover that I'll use a sheetmtal screw to attach it to the tin. This will only be a little larger than the hole and I can shape it to fit tight against the tin. Than use a small grommet to insulate the wire from the aluminum. You would have to remove the screw to pull the pulg wire but thats OK. Anyone seen anything different or better or have any thoughts on my plan? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Paul |
URY914 |
Aug 30 2005, 11:00 AM
'Cause I want something cool that works better and that no one else has..... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 11:12 PM |
