Help with rear brakes, what am I doing wrong? |
Kevin@ojai.net |
Aug 28 2005, 07:39 PM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
So, a few minutes ago I tried replacing my rear brake pads with out success. I was unable to retract the pistons far enough into the calipers to fit the new pads in. All I did during my failed attempt was remove the old pads, then pry against the pistons. This process has worked for me on other vehicles, but I had almost no luck on the 914. I was able to retract the pistons a little, but not nearly enough to get the new pads installed. What am I forgetting to do? What am I doing wrong?
-Kevin |
davep |
Aug 30 2005, 06:51 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Okay, but remember, you cannot force the piston back, you must use the adjuster. In the last 10 years I never seen the adjuster cap come off without a fight in a bench vise. Also, never use a tool on the pistons. I've seen Vise-grip marks on some sides and missing faces on others. That means a scrap caliper and very big bucks. If you don't know what you are doing, send it to someone who does.
Lo-Fi Version | Time is now: 6th June 2024 - 10:57 PM |
