Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
redshift |
Aug 4 2003, 01:51 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I have very good results dropping the front somewhere around 1.5 inches below the rear too, anyone else have a reason not to do that?
I level the car, then lower the front to add throttle-off oversteer until I am happy. Works better with rear bars, than withnot rear bars.. or whatever. What springs are you guys using? 180#s would be a great joke to play on an unsuspecting friend. (IMG:style_emoticons/default/smile.gif) M |
Lo-Fi Version | Time is now: 1st June 2024 - 01:51 AM |
