OT: Gotta get the Scirocco running, 16V CIS-E in a MK1 Roc. |
Series9 |
Sep 1 2005, 10:00 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Some of you asked about the S1 pictured here. It's been on the back burner for a while, but I started working on getting it running this week.
I picked it up last year from a guy who had installed a 16V engine from an '86, but was in way over his head electrically. I spent about a month rewiring the front of the car and sourcing correct boxes and sensors before I put it on the back burner to finish the RS. It hasn't been in service for over 10 years. I had to replace the gas tank, but it will now start and idle (roughly). I know the CIS-E system, but it's been a while. I did a differential pressure test on the distributor and got a control pressure that was HIGHER than system pressure. Logically, this shouldn't be possible. Any CIS-E gurus here? Attached image(s) |
pete-stevers |
Sep 1 2005, 10:11 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
I have a bunch of mrk1 stuff in the shop but the cis is out of a 8v motor....If the tank is rusty you are looking at big problems with the distributor as the filter may not take all the particulates out, or the plunger on the distributor may stick from rusting, depending on the moisture content of the fuel. I was ready to split the tank and get it re-coated and redo the fuel system before i decided to split with that rocco and got a second generation 16v.
steve |
Lo-Fi Version | Time is now: 7th June 2024 - 04:43 PM |
