Individual throttle bodies, Help me spend my money- |
ottox914 |
Sep 5 2005, 01:37 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Here I am stuck in UCLA- ugly corner of lower alabamma- (no disrepect intended to those who live here- its just not home for me) working on Katrina storm claims.
3 weeks of 14 hr days. Insurance adjuster. The storm bonus should cover cost of some used carb manifolds, throttle bodies, injectors, cross bar linkage, and some fuel rail bits and pieces. What to buy? Where to buy? What size to buy? Jenvy, TWM, Redline/weber, C.B., others? They'd be going a basically stock 2.0 with a Kerry Hunter header, euro p/c's, stock cam/valves/springs, and stand alone ECU system. The car runs SCCA DSP, so no changes to the long block allowed. I'd like to size the throttle bodies and injectors to be big enough to move on to a Jakester 2316 in a year or 2, when I save up some more $$ for his kit. Planning on the linkage from triad west, as it seems most complete, has had good reviews, and uses lots of heim joints. I like that idea. Any thoughts? Any real world experience? Thanks! |
Mueller |
Sep 6 2005, 04:41 PM
you'll want 2 CHT's...the stock CHT is fine for the ECU, all it is for it enrichment for when the motor is cold, basicly it is like an on/off switch.....putting it under the sparkplug would be overkill.......the ECU will be looking for a change in resistance..the under-the-plug type gives you a voltage and it might fry the ECU depending on brand and what signal it is looking for.... the other CHT you want for your gauge will be under the sparkplug as you mentioned for reading what the cylinder is really doing.... |
Lo-Fi Version | Time is now: 8th June 2024 - 08:18 AM |
