No high beams |
No high beams |
Tobra |
Sep 14 2005, 08:46 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
The low beams work, I can hear the relay clicking when I try to switch from low to high, and the L high beam flashes when I pull the lever, what could it be? I am going to get under there and clean up the contacts on the fuse block, where the wires connect, and where the fuses go. No horn either, but that is probably something else.
jgullock |
Sep 14 2005, 11:09 AM
Newbie Group: Members Posts: 37 Joined: 19-August 03 From: Warner Robins, GA Member No.: 1,045 |
I had the same problem - relay wouldn't latch. Ended up taking it apart (hey, what the heck. If it isn't gonna work what do I have to loose) and played with the contact distance. There are two contact plates with a smaller one in between - I messed with the distances - spread them apart a little. Works fine now.
Lo-Fi Version | Time is now: 1st June 2024 - 04:42 AM |
