| RON S. |
Sep 16 2005, 05:15 AM
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I wanna get some opinions on axle setups for the last leg of my 6r.
The car is an original 6,but it now sports a 993 engine,and 915 gearbox. Every system on the car is now fully functional,and is fully roadworthy. The last item left now,is acquiring CV's and a set of conversion axles. I'm gonna buy a pair of Empi 930 race Cv's for the trans flanges,as in the photo.And I'm gonna contact Sway-Away to have 'm make me an axle setup. Now for the quexchun. What to do,with the out board cv on the wheel end?The original hub is a 914/6 unit .4 bolt setup w/a Lobro cv. Some recent discussion involved using 944 flanges wjich would upgrade to the 911 6 bolt cv. Should I maybe should I maybe find & Modify a better flange to fit,or is the original unit satisfactory to use,and just get a conversion axle made. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Attached image(s)
| RON S. |
Sep 16 2005, 12:47 PM
Aaron, Does the 944 stub axle need to be from a Turbo, or will a plain 944 work? Am I also correct in assuming that the 914/4 & 944 cv's have the same spline count? The car does have the original 914/6 hub & flange on the swingarms. Ron |
RON S. Axle & Cv question Sep 16 2005, 05:15 AM
Aaron Cox save some money and go with 944 tubo CV's....(... Sep 16 2005, 10:05 AM
ClayPerrine My suggestion would be to use a 914/4 axle, modify... Sep 16 2005, 10:05 AM
brp914 sorry, can't answer - got same dilemma, but wh... Sep 16 2005, 11:03 AM
RON S. Sep 16 2005, 12:53 PM
Aaron Cox Sep 16 2005, 12:59 PM
RON S. http://www.914wo... Sep 16 2005, 01:26 PM
Aaron Cox do me a favor ron. look for some 33 spline CV... Sep 16 2005, 01:39 PM
ClayPerrine You do NOT have to change the outboard CV if you a... Sep 16 2005, 04:28 PM
Aaron Cox ![]() ![]() |
Lo-Fi Version | Time is now: 19th August 2025 - 08:26 PM |
