olav |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None ![]() |
My intermediate plate on my 901 tranny is seeping tranny fluid. How does one go about stopping the leak? Are there a couple of gaskets to use or some sort of liquid gasket. Also, when I take off the rear tranny cover to fix this thing are there any suprises that come springing out that I should be aware of? I'm thinking I can slid the intermediate plate off and apply the sealant and slide and re-assemble the whole thing again without too many issues. Also, are there specific torque values when re-assembling? Thanks. |
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
If the tranny is in the car, when you pull the cover off, reverse will drop on the floor.
The best way to re-install reverse is to use grease as a temp glue to hold all of the pieces in place, including the washer which sits on the intermediate plate. The manuals, etc do not suggest using sealant. I was told early on that greasing the intermediate plate before installing the paper gaskets would help. I now use a non-hardening gasket sealant and I do not get leaks. If the gasket is between the outer cover and the intermediate plate, there is only 1 gasket. Just install. If the gasket is between the case and the intermediate plate, it is actually a shim. The shims are color coded. Make sure you replace the correct one(s). Sometimes more than 1 gasket is used!!! James |
Lo-Fi Version | Time is now: 5th July 2025 - 06:02 AM |
