> is bus type IV 2.0 same as 914 2.0?, are newer 2.0's hydrolic lifters?
orange914
post Sep 22 2005, 11:06 AM
http://5starmediaworks.com/index.html
can anyone tell me if a late model bus 2.0 will work in 73 914 that has 1.7 fuel injection? what about;
1) computor/ injection calibration- changes
2) tin
3) any other issues
thanks any input appiciated
SLITS
post Sep 22 2005, 11:25 AM
"This Utah shit is HARSH!"
QUOTE (orange914 @ Sep 22 2005, 10:06 AM)
2) tin
3) any other issues
1. Pistons are deeper dish...lower compression
2. Crank & Rods are the same
3. Head are like the 1.7/1.8 except for the '79 which has Vanagon heads (different exh ports). Valves are smaller in size.
4. Dipstick is in lower case, not up top
5. Clutch & flywheel are different..228 mm as opposed to 215 mm and there is a difference in the ring gear placement. Teener flywheel\clutch should be used.
6. You would have to use 1.7/1.8 914 tin as tin is different
7. Brain and injectors are different.
About all I can think of at this point....it will work in a Teener with the above in mind.
orange914   is bus type IV 2.0 same as 914 2.0?   Sep 22 2005, 11:06 AM
Root_Werks   I am not really a 4cyl guy, so someone correct me ...   Sep 22 2005, 11:16 AM
ThinAir914   Although the 2.0L bus Type IV is essentially the s...   Sep 22 2005, 11:18 AM
SLITS     Sep 22 2005, 11:30 AM
SLITS   http://www.914world.com/bbs2/...   Sep 22 2005, 10:06 PM
Mueller
- Lo-Fi Version Time is now: 30th April 2026 - 01:43 PM
