> Valve cover weeps oil...sealant needed?
Air_Cooled_Nut
post Sep 22 2005, 11:13 AM
914 Ronin - 914 owner who lost his 914club.com
Okay, seems I have some oil leaking from the valve covers. The engine has new valve covers and seals. Installed dry. One thing I did notice -- and this may be the issue -- is that it appears that the valve covers were spray painted black. The entire cover. Would this [thin] paint compromise the integrity of the seal? I have the necessary tools to remove the paint if that's the issue. Or do the seals need Gas-A-Cinch or other sealant on them? If so, which side (head side or cover side)?
TIA again!
Joseph Mills
post Sep 22 2005, 12:12 PM
on a Sonoma diet now...
On my cork gaskets I use Permatex Hight Tack Gasket Sealent on the valve cover side only of the gasket. Let the sealent set up for about 5 minutes before fitting the gasket to the valve cover.
My covers are coated with a glossy epoxy paint finish.
Not a single leak yet. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Air_Cooled_Nut   Valve cover weeps oil...sealant needed?   Sep 22 2005, 11:13 AM
Tobra   I was advised by a Porsche mechanic friend of mine...   Sep 22 2005, 11:26 AM
rhodyguy   cork or rubber gaskets? check the edges and see if...   Sep 22 2005, 11:41 AM
Joseph Mills   On my cork gaskets I use Permatex Hight Tack Gaske...   Sep 22 2005, 12:12 PM
Cap'n Krusty   ...   Sep 22 2005, 12:14 PM
Air_Cooled_Nut   Yes, VW upside down...I remember reading that here...   Sep 22 2005, 12:18 PM
Cap'n Krusty
- Lo-Fi Version Time is now: 10th December 2025 - 11:35 AM
