| ThinAir |
Sep 22 2005, 05:44 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
I had to replace the master cylinder grommets for the reservoir lines. It went well enough except that I missed getting the rod into the master cylinder and had to take things apart to correct that. The way I did it was to loosen the MC from the wall and then remove the rod from the brake pedal arm so that I could slide the rod in place and then put it all back together.
As it stands now the pedal will travel back to the upper stop if I let off the pedal quickly enough so that it "snaps" back. But if I let off of it gently it will hang up with about 1/8" between the stop and the arm and I have to pull it back with my toe to get the brake lights to go off. I can feel it in the way the car drives if it's not all the way back - the car feels like I'm driving with the brakes on. Any idea what could be causing it to bind up in that last little bit of pedal travel? Having to pull back on the pedal won't keep me from driving it tomorrow to the Red Rock Classic, but I'd sure like to get it right. I can't see anything that is an obvious problem! |
| ThinAir |
Sep 22 2005, 08:21 PM
The car is clean and I just got back from a test drive - all is ready to go!! Woo-hoo! Moab, here we come!! (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
I think there is a conspiracy to ensure that I always have something last minute to deal with before an event - and usually it is something I've done to myself! Oh well, you learn from every mistake that you survive. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
ThinAir914 Strange brake pedal travel problem Sep 22 2005, 05:44 PM
Dave_Darling Spill any brake fluid? Any get on the bushings in... Sep 22 2005, 06:43 PM
ThinAir914 Found the problem. It's not supposed to be be... Sep 22 2005, 07:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 03:06 AM |
