> more CV questions
mightyohm
post Sep 23 2005, 12:38 AM
Two questions;
1. which side should the "ridged" side of the ball cage face when installed? towards the axle or away? I think it is away from the axle but I didn't take a good enough 'before' picture to tell (oops).
2. One of the used joints I bought in Ventura is different than the others. It has larger balls and a lot more axial travel than the rest. It shows some wear but not extreme spalling like on the ones I am replacing. Is this a rebuilt joint? Is more axial play normal in rebuilt joints?
Thanks in advance for any help. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
dmenche914
post Sep 23 2005, 11:13 AM
small balls may indicate a VW CV joint. What size balls do you have??? HA HA HA. Small balls in the correct CV should be no problem, although the load rating might be less. I had a mix of small balled and large balled CV's on one 914, niether one gave any problems driving a stockish 1.7 car.
good luck
- Lo-Fi Version Time is now: 19th July 2025 - 08:23 PM
