clutch problems... |
Mueller |
Feb 10 2003, 04:28 PM
installed new clutch cable...
on the transmission side of the cable, the nut is at the maximum threaded portion (tightened as far as possible) yet I could not get the clutch to release when pushing the pedal...so, I added a 1 inch spacer between the nut and the clutch fork... now the clutch will desingage but it feels odd when pressing the pedal... when I push the pedal I cannot feel any thing loose inside the tunnel to signify a loose clutch tube cable... what am I missing? I thought that if the clutch tube was broken that I would be able to feel it being loose inside the tunnel (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/blink.gif) Thanks Mike |
a914luvr |
Feb 11 2003, 12:03 AM
Member Group: Members Posts: 313 Joined: 6-February 03 From: Riverside, CA Member No.: 259 |
ya, Tony's prolly right. See if the throw out arm is hitting the tranny case when the pedal is pushed in. As part of a clutch job I always throw a shim (sometimes 2) under the pivot ball unless I'm using a brand new flywheel.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:40 PM |
