> Install front bearings and attach hubs
watsonrx13
post Sep 24 2005, 04:18 AM
This is a step-by-step instruction to install new bearings in the front hubs and attach the hubs to the car. I am going to make the assumption that you have already purchased new hubs or removed all of the seals and bearing from the old hub and had it checked for correct thickness and trueness. My recommendation is to purchase new hubs/discs.
When you get the bearings, remove the race and place them in a freezer. This will slightly shrink the race, so that you can start the installation of the bearings into the hub.
watsonrx13
post Sep 24 2005, 04:21 AM
I'm holding the large bearing. The next step is to completely pack the bearing with grease by hand. Take your time and make several passes, pressing the grease into all of the crevices, including the inner and outer edges.
watsonrx13   Install front bearings and attach hubs   Sep 24 2005, 04:18 AM
watsonrx13   This is what the back side of the hub looks like b...   Sep 24 2005, 04:18 AM
watsonrx13   I used the hammer to carefully tap the race down t...   Sep 24 2005, 04:18 AM
watsonrx13   This shows how I used the driver to seat the race.   Sep 24 2005, 04:19 AM
watsonrx13   This shows the race fully seated.   Sep 24 2005, 04:19 AM
watsonrx13   Next, I flipped the hub over. Again, you'll no...   Sep 24 2005, 04:19 AM
watsonrx13   Again, I removed the frozen race and set it in the...   Sep 24 2005, 04:20 AM
watsonrx13   I then used a 1 1/8" deep socket to carefully pres...   Sep 24 2005, 04:20 AM
watsonrx13   This shows the outside race fully seated.   Sep 24 2005, 04:20 AM
watsonrx13   Here's where the front hub attaches to the ste...   Sep 24 2005, 04:21 AM
watsonrx13   I'm holding the large bearing. The next step i...   Sep 24 2005, 04:21 AM
watsonrx13   Once the bearing is filled with grease, place this...   Sep 24 2005, 04:21 AM
watsonrx13   This shows the seal that will be pressed in the hu...   Sep 24 2005, 04:22 AM
watsonrx13   This shows the seal in place.   Sep 24 2005, 04:22 AM
watsonrx13   Throughout the installation, I have worn gloves. T...   Sep 24 2005, 04:22 AM
watsonrx13   This shows the slotted washer and nut that will be...   Sep 24 2005, 04:23 AM
watsonrx13   Attach the slotted washer and the nut. Please take...   Sep 24 2005, 04:23 AM
watsonrx13   Finally, smear some grease on the nut and install ...   Sep 24 2005, 04:23 AM
Brando   Yay! Nice how-to! http:...   Sep 24 2005, 10:34 AM
SpecialK   Most excellent pictorial! http://www.914wor...   Sep 25 2005, 09:48 AM
- Lo-Fi Version Time is now: 17th April 2026 - 07:12 AM
