Front mono-balls, Here is what I can find |
URY914 |
Aug 8 2003, 12:51 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've been able to find four manufacturers/suppliers.
Give me some feedback about these. They are as follows: These are made in Canada and are $195 CDN (US $??). They're inserts which use the stock housing. I've sent several emails to them with no replys. Attached image(s) |
philinjax |
Aug 10 2003, 05:36 AM
Member Group: Members Posts: 54 Joined: 26-March 03 From: Jacksonville, Florida Member No.: 476 |
Marc,
I agree, if you pull the dust cover off the strut, it may allow a sudden heavy bottom out, like a pot hole hit, to pop the rubber bearing out. The teener stock trailing arms are about as flexable as a brick. You don't need no stinkin boxing to add weight. Sure, if you get a little loose around that corner and slam the outside wheel against that curb, something is going to bend or break. Would you rather it be a suspension console or a trailing arm? Tim, Did your friend's car have the shock dust covers removed? philinjax (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 08:53 AM |
