Engine bay seals Production run?, Deciding on if I should make some |
Mikey914 |
Jul 21 2005, 12:10 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'm not sure about you, but I've been looking around at the cost and availability of engine compartment seals, and I'm amazed at how expensive these are. Mine were all baked off from a fire, and I must replace all.
I can make these, but to break even on the die I need to find 40 people that would buy them at $50. I might just have them made if there is enough serious interest. I'm not sure that there's that much interest, that's why I thought I might post this to see. Also as I understand there are 2 different seals I above the engine, and the other 3 sides are the same. If all 4 are the same the cost would be significantly less as only one die would be required. I'm not looking to get rich, I just want to get some parts at a more reasonable cost. -Mark |
bottomend |
Oct 3 2005, 08:56 PM
Member Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 |
Engine is out and I'm rebuilding it. good time for new seals... is this still happening?
