John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
I'm looking for some pics of 915 transmissions installed in 914-6 with the 915 trans cooler in place.
Is there sufficient room between the cooling tubes and the 914-6 headers? Can the cooling tubing be bent to clear the headers? Please post pics if you have them. Thanks |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
i have such a transmissionm a 915/67. not installed yet - it is intended for the 911. i can take whatever photographs or measurements you'd like.
the cooler loop is *very* soft, ribbed brass or aluminum; i think you could bend it pretty much any way you liked. it fits to the transmission with O-ring seals and i think it'd be "almost" trivial to use real fittings to run hose to a proper radiator-style cooler mounted anywhere. here it is mounted in a 911 - it's over that duct/rockshield top center left. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 14th July 2025 - 02:48 AM |
