| Mueller |
Oct 5 2005, 11:12 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
All aluminum, good power and reliable....pretty cheap as well since about the only market for them is for replacements or sandrails.
A few sites with some good reading about them: C and G Performance and Funco sandrails I know Kennedy Engineering makes an adapter plate and flywheel for it as well and unlike most Honda 4 bangers, they turn the correct direction (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.cgperformance.com/images/CG%20honda%20engine%20WP.jpg) |
| dmenche914 |
Oct 5 2005, 02:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Now them is some impressive figures, thanks. Yeah, old type I VW motors are not top of the line anymore in sand rails, my uncle has a Rover V8 Turbo Aluminum enigne in his rail. I think the rail weighs under 1000 lbs, that might even be with driver, I forget!
Subarus have the advantage of keeping the weight down low with the flat design, I believe the oil pan does hang lower than the 914 engine, but it can be modified to gain back some of the ground clearance. Again, the subaru sells for a bit, they are less common than Hondas, and they are snapped up by other engine swappers and kit car folks (nice swap in Vanagons) Mike, is the V6 in the photo altready yours? If so can you figure if you need to cut any of the body to fit it? On my Buick, the front engine shelf had to be notched to clear the water pump shaft. What about a engine bay radiator, that would really be nice, save cutting up the front trunk, Anyone seen this been done? |
Mueller Will anyone install a Honda/Acura V6 into a 914? Oct 5 2005, 11:12 AM
dmenche914 Mike: sounds like a great idea, You know I have a... Oct 5 2005, 11:21 AM
Tobra The S2000 engine spins the right way too. Vibrati... Oct 5 2005, 01:23 PM
airsix Oct 5 2005, 01:26 PM
URY914 Isn't that the engine they use in the ATOM?
P... Oct 5 2005, 01:26 PM
Mueller Oct 5 2005, 01:26 PM
airsix Oct 5 2005, 01:30 PM
Mueller Oct 5 2005, 01:48 PM
Andyrew I'd do it.
If the S2k motor turns the correct... Oct 5 2005, 02:04 PM
Mueller Oct 5 2005, 02:06 PM
Andyrew true...
It will still sound small... me thinks...... Oct 5 2005, 02:13 PM
MattR Oct 5 2005, 02:16 PM
dmenche914 still haven't seen any HP and torque numbers. ... Oct 5 2005, 02:17 PM
d914 s2000 vetech kicks in at 6k with a 9k redline 240h... Oct 5 2005, 02:22 PM
Andyrew v6 is 225 with 250 capable with headers and tuning... Oct 5 2005, 02:22 PM
trekkor Doesn't the S2k have a 9000k redline and make ... Oct 5 2005, 02:24 PM
Mueller as copied from Funco:
<... Oct 5 2005, 02:26 PM
914GT Just got my wife a new Acura TL a couple weeks ago... Oct 5 2005, 02:27 PM
Mueller oh yea, huge price difference between the S2000-4 ... Oct 5 2005, 02:30 PM
fiid BTW: Don't forget that if the motor spins the ... Oct 5 2005, 02:42 PM
Mueller Oct 5 2005, 03:27 PM
Twystd1 I know where two s2000 engines are with blown head... Oct 5 2005, 04:09 PM
Sammy I've seen an S2000 rev to 9300 with no problem... Oct 5 2005, 04:37 PM
jimtab I own a '95 Acura Legend with the very v6 you... Oct 5 2005, 10:07 PM
dmenche914 aint so much the weight moving tot he front, i jus... Oct 5 2005, 10:53 PM
914GT Oct 7 2005, 12:20 AM
grantsfo Does the 1.8 2ZZ-GE used in the Celica spin the ri... Oct 7 2005, 12:39 AM
Mueller <... Oct 7 2005, 09:37 AM
andys Oct 7 2005, 10:06 AM
WRX914 Oct 7 2005, 10:18 AM
Mueller Oct 7 2005, 11:42 AM
BIGKAT_83 Oct 7 2005, 12:34 PM
brant Oct 7 2005, 12:43 PM
andys ... Oct 7 2005, 01:32 PM
Andyrew You can run an autox course in one gear with a sbc... Oct 7 2005, 02:13 PM
Brett W On the Honda electronics, You will have to do som... Oct 8 2005, 01:00 AM
Twystd1 Brett,
I spoke to my Honda friends the last couple... Oct 8 2005, 01:28 AM
Mueller thought I'd http://www.914w... Feb 27 2006, 12:19 AM
riverman I had two '91 Acura Legends when I aquired my ... Feb 27 2006, 07:03 AM
Porcharu Feb 27 2006, 10:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:21 AM |
