> not so technical how to, vapor barriers for dummies
rhodyguy
post Oct 6 2005, 07:26 AM
starting point.
k
rhodyguy
post Oct 6 2005, 07:53 AM
i would suggest you use 1mil or thicker plastic for the barrier. painters drops work fine. i found this in a box. i think it was for the jetta. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) . after you get the plastic on, open all the holes for the plastic clips and the 2 grab handle screws. easier than trying to shove the clips through the solid plastic. the adhesive on the
is plastic made it super easy. for plain plastic, i use "Permanent Double Sided Scotch Tape" around the inside of the perimeter where the edges of the plastic are. i wiped the perimeter down with denatured alcohol so it would stick well. trim excess with a utility knife or exactoknife. a RAZOR SHARP NEW BLADE WORKS BEST!
k
- Lo-Fi Version Time is now: 9th June 2026 - 04:21 AM
