> Official "White Bitch" Build Thread - Please comment., PICTURES! - I'll rename here when i dont hate her anymore...
snflupigus
post Oct 9 2005, 10:28 AM
Please take a look at these items for me and leave any comments you have...
http://www.snflupigus.com/914issues/914issues.htm
ONE OF THE PICS - Please look at the rest.
(IMG:http://www.snflupigus.com/914issues/images/140_4031.JPG)
dmenche914
post Oct 9 2005, 01:25 PM
You ought to be able to get the aluminum channel from a swap meet, or post a wanted ad for a pair (right and left are different, get one of each) The channle screws onto the roll bar with some sealant under it, then the rubber slips in (with a small screw to prevent it from moving out)
If only the fire wall is bad, and floors are good, then when the engine is out, remove the rust, see if some one is parting a wrecked 914 and try to get the firewall to use as a patch panel, or make your own. A fiberglass patch could also be done. Just do your best to arrest further rust, and seal the holes so it don't get wet inside when you wash the car. A new engine shelf for the passengerside is made by Restoration Design (they might even make a firewall) It is easy to install with motor out, and a MIG welder This will allow better engine bay sealing from hot air.
A good area to inspect is behind the outer rocker covers, especially near the jack point.
good luck!
snflupigus   Official "White Bitch" Build Thread - Please comment.   Oct 9 2005, 10:28 AM
dmenche914   the rubber strip needs a aluminum channel to slip ...   Oct 9 2005, 10:45 AM
snflupigus   i've found no other rust on the car. the front...   Oct 9 2005, 01:12 PM
dmenche914   You ought to be able to get the aluminum channel f...   Oct 9 2005, 01:25 PM
jasons   You have a Chalon, right? That might be why you d...   Oct 9 2005, 09:18 PM
snflupigus   Ok... page above updated.... here it is again: h...   Oct 9 2005, 09:36 PM
Engman   You definately need to repair the hello hole and o...   Oct 9 2005, 09:56 PM
snflupigus   I do have the Chalon... The fiberglass is smooth u...   Oct 9 2005, 11:28 PM
jasons     Oct 25 2005, 11:47 AM
MattR   Its a 914 http://www.914world.com/b...   Oct 25 2005, 11:50 AM
snflupigus   see the updates.... FUN! http:/...   Jan 26 2006, 01:36 AM
snflupigus   and more updates.... car is comming apart nicely L...   Feb 11 2006, 10:37 AM
snflupigus   btw - i'm pretty sure i'll be selling the ...   Feb 11 2006, 10:40 AM
bmunday
- Lo-Fi Version Time is now: 16th April 2026 - 10:27 AM
