http://www.snflupigus.com/914issues/914issues.htm
ONE OF THE PICS - Please look at the rest.
| QUOTE (snflupigus @ Oct 9 2005, 09:28 PM) |
| All the donuts look ok.... thats what you are talking about for jacking points right? As for the hell hole... although it is bad, I want to pull the motor, fix anything structural and seal it up, including the firewall of course. The engine shelf I'm not worried about because I wont have the type 4 in there for long. I'm thinking either a ls1 or 5300 vortec chevy or any gen IV mated to a boxter trans. |
| QUOTE (snflupigus @ Oct 23 2005, 11:03 AM) |
| major question.... best stuff to remove the GOO left over from the tar? wire wheel does nothing... and i'm begining to think this angle grinder and wire wheel combo are not the best rout for lots of this... do i need to go buy an air sander and a compressor? |
| QUOTE (Bumper @ Oct 23 2005, 12:17 PM) |
| My stock rear window seals are glued, not screwed. |
| QUOTE (TROJANMAN @ Oct 25 2005, 09:14 AM) | ||
you can also try getting a paint stripping gun to heat/soften up the tar, then use a puddy knife to scrape it. the gun will probably cost you $10-$15. |
