Handy welding tip, Filling gaps in thin metal |
Rand |
Oct 9 2005, 08:10 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I've been MIG welding quite a bit of sheet metal today. A couple of times I had to deal with some gaps and the metal was a bit thin for my welder's lowest heat setting.
Tired of blowing holes? Coat hanger to the rescue! Yep, a good use for those old wire coat hangers... Kind of like gas welding with a torch... feeding the rod into the pool. You can feed the coat hanger into the area you are wire welding and fill the gaps. Get some filler in there and melt it into the sides... Works quite well. Works good for small holes too... lay the wire across, melt off pieces as you need. Then melt it across and grind it off flush. I'll start my progress thread soon too, but just thought I'd share a quick tip that came in handy today. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
ChrisFoley |
Oct 11 2005, 07:20 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Thats what I usually use (graphite), but they get hot too. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:49 PM |
