Barbecued Pertronix and No Start, God laughs at me alot |
Brian Mifsud |
Aug 10 2005, 11:51 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Poured in the 3 gallons of premium, hooked up the brand spanking new Die Hard and hit the switch for the first time in 6 years... annoying seat belt buzzer seems to work very well...........
So I hear the fuel pump fire off (good) Starter Solenoid goes click................. Try again.............click turn off ignition and climb out (I COULDN't have wired the starter wrong.. .there's only 2 connections) me says.. Then the wonderful smell of burning bakelite.......... I quickly disconnect positive terminal to battery and bust open the distributor. I conclude that I roasted my Pertronix having wired it wrong when I had to remove and replace the coil (although my red wire went to positive post on coil, and black wire to negative so what gives???) Mind you, this was a perfectly running Mike Mueller engine with a perfectly running Pertronix Ignition.. I had to go and mess it up by taking things apart to clean them all up. Last time I used it, the starter was dandy with no problems. Would I be lucky enough that this has happened to you.. and the only reason the engine DIDN't turn over was lack of voltage 'cause that greedy Pertronix was wired wrong and sucking up all the AMPS?? In other words, is it likely I have MORE than one item wired wrong?? New ignition on the way, but I'm not using it as a fuse agin.... see, this Idiot can learn things..... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ArtechnikA |
Oct 17 2005, 12:22 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Friday i had the ignition on in the development Mini for 4 hrs. ... we do this frequently. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:37 PM |
